2005 xk8 security locking module resistor values
Hi,
Can anyone help me in identifying the wattage of the resistor in the slm.
I have had problems and on taking apart, found that the resistor R92 has burnt out. The R79 resistor next to it shows 1ohm but no wattage?
I would rather solder in a new resistor than pay £400+ for a new module.
Any help would be greatly appreciated.
Al
Al
That physical size should not be over 5 Watts, so 5 watts will be safe. The 'J' means 5% tolerance. If that is a 1 ohm, this would be a good candidate: http://www.digikey.com/product-detai....0CT-ND/596682
albiss (12-06-2014)
That physical size should not be over 5 Watts, so 5 watts will be safe. The 'J' means 5% tolerance. If that is a 1 ohm, this would be a good candidate: AC05000001008JAC00 Vishay BC Components | PPC5W1.0CT-ND | DigiKey
Al
Good point Steve. Most higher wattage resistors these days are flameproof. The one I referenced has a ceramic core and a ceramic coating.
What problems have you been having with your SLM?
I've been told I need to replace mine & have been looking for a used replacement but have been unable to find one so the idea of fixing it with a new resistor sounds good to me.
![Icon Biggrin](https://www.jaguarforums.com/forum/images/smilies/icon_biggrin.gif)
Quite random faults really, first the central locking is playing up, keeps rolling on the door catches (clicking in the out) now have to use key to open and lock as fob just activates/deactivates alarm.
Then i lost my rear lights on passenger side, brake lights work okay but annoying having the check rear lights message when lights come on.
The SLM is easy to remove and seems to be the culprit? when taken apart found the resistor blown, I'm hoping this is all as £400+ for anew module is excessive and no doubt will also be needed to be reprogrammed by Jag?
Al
Hi Jon,
Al
Al
albiss (12-09-2014)
Al
Al
My problem is the "check rear lights" warning after a few prods of the brake pedal so please keep us informed of your progress.
By the way, exactly where is the SLM located, I know it's in the boot but I'm not sure where & how difficult is it to take apart?
Thanks for your help
![Embarrassment](https://www.jaguarforums.com/forum/images/smilies/redface.gif)
Thanks Al,
Thanks for your help![Embarrassment](https://www.jaguarforums.com/forum/images/smilies/redface.gif)
Al
Al
99xk8guy
06-05-2023 06:28 AM
KarimPA
09-12-2015 08:15 AM
