2006 XK Convertible Headlamps
Old 05-21-2015, 10:12 AM
donovanwestover's Avatar
Default 2006 XK Convertible Headlamps
I am new to the forum and wish I knew it existed with my two previous Jaguar XJ6s. I recently purchased a 2006 XK convertible and have lots of questions, because it did not come with the Owners Manual. The most pressing inquiry being that one of the primary headlamps occasionally blinks, but to this point stills operates 80% of the time. Can anybody tell me if this is a bulb (that I may be able to change), or does the entire headlamp assembly need to be replaced by a mechanic? Thank you in advance.
Old 05-21-2015, 11:49 AM
Gary G's Avatar
If you have Zenon HID the D1S bulb probably needs to be replaced. HIDs tend to sputter a bit and may change color towards red/yellow at the end of their lifespan. Don't wait too long because a bad bulb can take out the controller if it's not replaced.
Go with a name brand, as the cheap knock offs from Asia rarely last. Some advise changing bulbs in pairs because the other bulb is typically not going to last much longer.
Old 05-21-2015, 11:50 AM
blindside's Avatar
I can't really speak to the blinking headlight (but it sounds like it could be a loose connection of some type), but HERE is a link to a forum page by GGG that has some pdf versions of the various manuals (I couldn't seem to get the "insert link" button to work so here is the full link)https://www.jaguarforums.com/forum/x...006-faq-67827/)...
Hopefully you can find the proper one for your model year.
And for hard copies eBay is probably your best bet.
Old 05-21-2015, 12:02 PM
WhiteXKR's Avatar
Received 2,985 Likes on 2,124 Posts
Once you reach 10 post and 3 days on the forum, you should be able to download your missing Owners Manual per this thread: https://www.jaguarforums.com/forum/x...006-faq-67827/
It can also be downloaded from the Jaguar Topix website.
rentzoo
11-10-2015 04:56 PM
Na5h
09-11-2015 07:26 AM
SCMike
09-09-2015 09:30 AM
Nasayr
09-09-2015 06:20 AM
1100me
09-07-2015 06:26 AM
Quick Reply: 2006 XK Convertible Headlamps
