2006 XK8 front calipers
Yes. Rick (joycesjag), Wayne (cjd777), and I have done the ZF 6HP26 drain-and-fill procedure three different times on my wife's 2006 XK8 (now approaching 118,000 miles). The job goes much better with at least two people working on it (one underneath the vehicle pumping the fresh ATF into the fill hole in the transmission pan and one in the drivers seat putting the transmission through its various gearshifts while the engine is running and the fresh ATF is being pumped in underneath). Like many owners here on the forum, we switched to Mercon SP ATF on our second drain-and-fill procedure (available at any Ford dealership parts department). It meets the required Shell M1375.4 ATF specs and it is much more cost-effective than ZF's Lifeguard 6 ATF....
The first time we did this job (about 67,500 miles in July 2013), we replaced the pan/filter and Mechatronic sleeve and used ZF's Lifeguard 6 ATF. The second time (about 100,700 miles in April 2016)) and the third time (about 106,000 miles in November 2016) were just drain-and-fills switching to Mercon SP ATF and attempting to get as much fresh ATF into the system as possible. The key is to have all the necessary tools and to crack open the 8mm Allen fill hole plug BEFORE you drain the old ATF out of the pan. If you cannot remove the fill hole plug you will be dead in the water if you drain the old ATF first....
GGG (11-08-2018)
In future, keep a thread "on topic". If you had started another thread to ask the transmission fluid question, the excellent reply from Jon would have been available to anyone searching for advice on transmission fluid changes. No one will ever think to look for it in a thread about front brake calipers.
