2006 xk8 locked in park
Could it be as simple as the parking brake wasn't set BEFORE the car was put in park on an angled driveway? The rocking you mention to free it up leads me to suggest this. The parking pin in a transmission was never designed to hold a car in place. 4000 lb's resting on a pin the diameter of a pencil can cause binding. I've seen stuck ignition locks and stuck gear shift levers because the parking brake was not set prior to putting in park or the ignition key turned to off. Put the year and model of your car in your signature please.
Salu498 (07-21-2016)
Another suspect is the brake switch. When the brakes pedal is pressed, the switch eventually causes an actuator to free the shifter. In a quiet environment, you can hear a click. In the worst case, there is a plastic plug near the shifter. It is for a manual override of that interlock, and get you moving again.
The following 2 users liked this post by fmertz:
grantorino62 (07-21-2016),
Please put your year and type of car in your profile signature. You own a 10 year old Jaguar and you're not mechanically inclined! No owners manual? The cover for the release is in the shifter console. About a quarter inch square. You remove this cover to press the release pin. If the release solenoid is faulty, you will be doing this every time you try to put it in gear.
Received 4,319 Likes
Salu498 (07-22-2016)
mikelanzetta
05-06-2016 12:14 AM
