2006 Xkr battery replacement
So my battery died. I got over 7 years from it and after leaving the car sit for a month and a half it was dead and after charging overnight the specific gravity is still very low but it starts the car. Maybe not tomorrow though. I am not complaining but the previous battery was replaced by Jaguar and they used a Jaguar 90 amp T8-90J battery. So in looking for a replacement I did a search for that battery and could not find any but I found a number of H8 batteries that list as made for the vehicle. While I believe they would work fine I wondered what the actual battery replacement that the manufacturer calls for, a T8 or H8 and for that matter what is the difference between the two, they both vent outside and look about the same. Not a big deal just wondered if I could get some information from a battery expert on the forum.
I found the difference, The H8 is just a little taller than th T8. Don't know that this works but I left the battery charger on for the last 4 days at 4-5 amps and the specific gravity slowly came up the good level on a hydrometer. After removing the charger the voltage slowly dropped from 13.4 to 12.8 and seems to be stable there. I did this two years ago with another battery and its still running in one of my cars that I rarely used. I will see what happens with this and make sure my AAA is up to date.
Definitely an H8. Several different opinions about AGM vs Lead Acid for our cars, but I've had good service out of my Champion H8-900CH AGM battery from Pep Boys. Bought it online with a seasonal discount and they installed it for free. Good reading here: https://www.repairsmith.com/i/blog/agm-vs-lead-acid/
True, charging dynamics are different between the two batteries, but I haven't had a problem out of mine. I keep it on a monitor/trickle charger when parked haven't had any trouble out of it in 4.5 years, a rarity given the summer heat of Las Vegas. Would be good to hear opinions/experiences from other Forum members...
Received 1,665 Likes
I’ve got 3.5 years and about 60,000 miles worth of using the starter, lights, etc on my AGM battery. I sourced it from a NAPA parts store.
I keep the car on a Delran Battery Tender + when it is parked overnight or longer. Actually I can’t recall the last time the car sat unused for a 24 hr. period.
Z
still good
Mikey
04-13-2017 07:59 PM
