2006 XKR pops on hard excelaration
I have 2006 XKR When i excelerate hard it surging, backfires,and power lose.
Installed new NGK Ir plugs, checked for vacuum leaks.
fuel pressure stays around 54psi. only code is P0171.
all works fine with slow acceleration
Also when I bought the car lat week both seat modules are missing
Dealer says the part # LJE2160AB Discontinued. I cant find them anywhere
also 30,000 miles on the car
I was reading another post on here about 4.2 engines and how they changed the fuel delivery systems. it said some times the fuel pressure transducer can go bad. So I walked out to the garage and figured I would pull mine off and clean it. I was not thinking about the fuel pressure on the line so of course fuel went every where. But not long. as I just stared at it I noticed its just blowing air. I let it finish and put the sensor back on and it seems to be working fine now. No more stumbling or exhaust popping noises. I have not driven it yet.
Could it have just been air in the fuel rail?
This sounds similar to a problem I'm having with a 2003, minus the pops and no backfire. It seems the car sort of falls on its face just slightly, when taking off from a full stop. I always thought there might be a transmission vacuum or electronic part to investigate, but had not considered the fuel delivery aspect. There's never any problems once the car gets going though - that's the odd part.
FS[MidWest]: parting out my 97 xj6
salP3082
10-31-2016 09:11 PM
