2006 XKR trip mileage, A and B
Hi folks... you were so nice to help a newbie with his tire/wheel question.... now more questions:
My 2006 XKR has a funny issue. The dash control panel for the A/B trip mileage, etc.. seem stuck on the "A" setting. Nothing I push resets the trip mileage (in either "A" or "B") it or changes it to "B".
Thoughts or comments ????
Follow this video: ‪sam1174's Channel‬‏ - YouTube. You only need to go as far as removing the wood panel.
Then make sure the switch cluster is plugged into its cable.
The buttons on the trip computer are very similar to those on your key fob; rubber pads that mash over some traces on a circuit board. My car came with one of the buttons mashed in and stuck. When I finally pulled it apart it had just mashed a plastic piece out of the way so it wouldn't work right.
If re-seating the plug on the back of the button cluster doesn't work, push the cluster out of it's holder. It pops out toward the driver after you squeeze the two tabs on the side. (DON"T take out the holder, it stays attached to the wood panel) Then open the cluster and clean the circuit board with rubbing alcohol the same way you would clean the circuit board on the key fob. It might help.
adam699
09-12-2015 05:32 PM
FS[SouthEast]: 2006 and 2007 Jaguar Media Press Kits
SCMike
09-09-2015 09:30 AM
