3D Print Seat Release Airbag Badge
Part GJE4758AA is now NLA. I bought the last one from what we were able to discern.
However, I did CAD it using TinkerCad and printed a prototype. It fits, not perfect, but works. I had the "AIRBAG" text but it never printed correctly, so I just went with a plain front.
The design is attached and below and free to use. I'd probably print in ABS or Nylon.
If you enhance the design, all I ask is you provide me a copy so I can update.
The picture below will show the OEM (painted Phantom White with SEM Color Touch-- a decent NED option) and then the 3D print in purple. You can see why I removed the lettering. Perhaps if I made it deeper and used a commercial printer it would have been better (?). Also note that OEM one has a broken top tab. That 3D print was just a prototype made of IPE (so not the best material) and done on a consumer grade printer.
https://www.tinkercad.com/things/kjI...adge-gje4758aa
The following 3 users liked this post by dsd:
Some pics. These are just prototype quality but wanted to show the fit.
Here is one of my old and broken Escutcheons. Using the Seat Washer posted by another user, I can fix the cracked back. Then, we have the cover I designed.
If you are doing this make sure you use the right material for temperature ratings, like ABS, PETG, etc...
