4.0 AJ-V8 to 5.0 AJ-V8?
There are easier ways to get the power of a 5.0 (and more), really.
How deep are your pockets on this project? Anything is doable with the right budget, but you have to ditch the cars electronics, and go custom here. You could probably start with checking the 5.0 ECU if that one could be used to at least control the engine and possibly the gearbox as well. So investigate all the in/output pins, and see if that can be supported in one way or another.
Otherwise you need to get your own programmable ECU and other type of transmission, that will be some work. I guess that mechanically fitting the engine and some transmission could be doable, plate/frame work is off course relatively easy.
Another thought would be to make body panels so the 5.0 XKR looks more like ours.
Or get a XK8 and put a ls engine in it, at least you will keep there the Jaguar electronics.
Thank you guys, I want to keep my 02 XKR and just do a motor, maybe trans swap. I was also aware that there would be a ECM swap needed. I was just wondering if anyone had done it, could give me some insight. Like are the motor mounts the same, will the 4.0 trans match up to the 5.0 block, what changes are needed regarding ECM... things like that.
I know purists would say don't mess with it. But this will be one of a kind XKR and I will be doing several things to it. I want to make this a true performance vehicle and not a sport tourer.
Some of the things I have done so far are:
Smaller Supercharger Pulley from Mina Gallery
Cold air intake from Mina Gallery
High Flow Exhaust from XK's Unlimited
And True Spoked Wheels from Master Wheel Smith in the UK
I am replacing the wood trim & Steering Wheel with Carbon Fiber from JAG Interiors in the UK
I am also removing the back seats and having a roll bar put in that I saw on this forum and will be adding a race tuned suspension.
So as you can see, I will be putting money into this project and would just like to see if I can put a bigger engine into it or if I will have to just "Build" my existing 4.0 and get as much horsepower out of it as I can without blowing it up.
Superchargedxkr (03-11-2023)
This is my question, I very much like this idea but am unsure where I would get this kit….. Where can I find this kit? Is it just replacing the screw inside the Eaton m112 or is it an entirely new supercharger? For reference, I have an 02 jaguar xjr.
I would say tuning and modifications to the 4.0 you have is the way to go on this, better intake. Uprated/ faster? Supercharger via pulley changes, then higher flow injectors, but definitely with a suitable tune from someone reputable that knows about this, remember head gaskets have never been a strong point on these motors.
Good luck
I love your enthusiasm 👍🇬🇧
Good luck
Superchargedxkr (03-12-2023)
This may be of interest
https://www.jaguarforums.com/forum/x...2-x100-173398/
Or this
https://www.jaguarforums.com/forum/jaguar-engines-transmissions-47/aj-v8-engine-32738/
Or this
User 070620
01-13-2017 02:14 PM
