4.2 Lower Pulley Upgrade
I called Eurotoys to order the upper and lower pulley package. Unfortunately the lower pulleys are out of stock for 2-3 weeks. I did some further research this morning and read that "the 4.2 engines already have a larger lower pulley...so the upper pulley is the only option before big time twin screw upgrade from Avos."
I couldn't find a single instance of anyone upgrading the lower on a 4.2.
Has anyone tried the Eurotoys lower pulley on a 4.2? What were the results? For $1000, I'd hope to see a noticeable improvement. Before I drop the loot, which I'm prepared to do immediately, I was hoping for some feedback from you guys. Thanks.
Just to clarify
This is the lower pulley I was going to purchase.
http://www.eurotoysltd.com/catalog/p...oducts_id=1466
It says, "This supercharger pulley kit will give you a MAJOR power improvement of 50-60HP when coupled with 1 of our upper pulleys." but says nothing about the psi or performance of the lower by itself.
I've been searching on and off all day and still can't find a testimonial for this crank pulley on a 4.2...
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
10-24-2015 05:46 PM
Ipc838
09-13-2015 03:27 PM
rachelstr
09-03-2015 12:59 PM
