4.2 xkr brembo brakes & calipers
Can you clarify what you are looking for? These Brembo calipers are hard to find and pricey if you can find them. They are unfortunately not shared with the S-Type R. There is compatibility with the older X308 XJR I believe. If you have a set, best is to look at rebuild kits, etc, if necessary.
Rotors/disks seem generally available. I went with RockAuto, but there are other options.
There are options for pads. The Jaguar/OEM I have are very dusty (they came as "loaded" calipers).
Best of luck, keep us posted.
crocodile62
17
04-13-2010 03:00 AM
