4.2L AJ33S Engine
Hi I have a couple of questions about an engine in a 2003 XKR, that I am hoping someone can clarify for me. What is the difference between the AJ33 and the AJ33S? Is there a physical difference, (bigger crank journals, bigger block webbing, etc.) what I am getting at is would an AJ33 long block work in place of an AJ33S long block. Is the difference just that one is supercharged or does the supercharged engine have a stronger block? Thanks for any info you can share on this.
Compression ratio is lower the n the S/C version, that's a big difference. There are some other more subtle things like the oil sprayers to cool the bottom of the pistons, or the VVT that the N/A engine has that the S/C doesn't.
The long (or short) block are not interchangeable if you are thinking of an engine swap.
OkieTim
09-08-2015 04:48 PM
