96 XK8 - ABS light not switching off for circa 12 seconds
Old 02-24-2013, 09:54 AM
Frog's Avatar
Originally Posted by steveinfrance
That's a disgraceful idea.
Damn right. Members who countenance that sort of behaviour should be banned.
Old 02-24-2013, 10:04 AM
steveinfrance's Avatar
I can't ban myself - should I ban Jim which will close the whole Forum down ?
Old 02-24-2013, 10:31 AM
batroute's Avatar
UKMOT.com MOT Manual 3.4 ABS Systems
Sorry guys, (although you might fluke it if the tester is not on form that day)
Old 02-24-2013, 11:07 AM
Frog's Avatar
When did ABS become mandatory in the UK/EU? If it was after 1996 - when the OP's car was registered - won't he be ok? I had an engine warning light on my Mini Cooper when I took it for its French MOT last year, but the tester ignored it because it was a 2001. Just a thought...
Old 02-24-2013, 11:35 AM
batroute's Avatar
My understanding is that if the (ABS) system is part of the original fitment(which it was) then it's a testable item. I've been out of fleet management since 2009 so I can't claim to be current on regulations but it would be highly unusual if VOSA took a retrograde step on compliance with a safety item.(or anything else for that matter).Things changed when they became a government agency charged with being self sufficient financially. Last I heard (2009) they were up for privatisation or such like. There may well be MOT testers on this forum who can correct me if I am wrong. I also think there were moves afoot to abolish testing at three years old and carry out the first test at (I think) the fifth anniversary of registration - not that this would help the OP.
Old 02-24-2013, 12:45 PM
MarkyUK's Avatar
Done all except the soldering, however I now have TC/SC control failure as well as the ABS warning light permenantly on, so not as simple removing a bulb now :O(
Will send the unit away to not only have the pump soldering done but an overhall of the PCB...quite cheap at £100
Old 02-24-2013, 12:52 PM
MarkyUK's Avatar
Frog ABS is not a requirement even for new cars just that everything fitted must work.
For example I am looking to fit aftermarket front fogs as one of them is broken...I just removed them completely and therefore no fail.
Would be good to disable it but not terribly safe
  #28
Old 02-25-2013, 02:27 AM
Let us know how you get on. Good luck.
Old 02-26-2013, 12:38 PM
MarkyUK's Avatar
Here's the kicker, not driven it for a couple of days, started up this morning and ABS light switches off after 3 seconds with no TC/SC warning. So drover 3 times and started up another 10 and all ok.
Took for MOT and passed!
Funny foibles these cars have!
  #30
Old 02-27-2013, 10:31 AM
See the advantages of Forum membership ?
If nothing else you've gained sorting-out time.
  #31
Old 02-27-2013, 03:14 PM
MarkyUK's Avatar
Today though ABS light stays on and TC/SC fail messages
What a car!!
Hey now got a year to sort it out before next MOT!
  #32
Old 02-27-2013, 05:08 PM
oyster's Avatar
Hi.
It is not that strange. A bad solder joint in the module, a harness on the way to break or bad connector may give you these symptoms, warning light comeing and going.
D.K
12-10-2023 02:05 AM
99xk8guy
06-05-2023 06:28 AM
Shawn Svacha
11-04-2019 02:47 PM
laserguy
09-03-2015 02:02 PM
innzane
09-02-2015 10:08 AM
Quick Reply: 96 XK8 - ABS light not switching off for circa 12 seconds
