97 Belt tensioner
Old 12-09-2010, 05:56 PM
brgjag's Avatar
Default 97 Belt tensioner
Is there just one serpentine belt tensioner on my 97 Xk8? 10k miles ago the noisy acc belt idler and tensioner pulleys were replaced, idler, tensioner with updated assembly. Sound to me they replaced all of that stuff? I ask cause it is squeaking again.
Old 12-10-2010, 09:08 AM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
That's all there is...and idler pulley, and tensioner w/ pulley. If its squeaking again, its more than likely the belt this time. (or another pulley on another accessory - altrernator, water pump, power steering pump, etc)
Old 12-10-2010, 11:42 AM
brgjag's Avatar
It is not a belt. This sounds like the classic bearing sqealing.
Old 12-17-2010, 02:59 PM
brgjag's Avatar
So as I see/understand, looking at front of motor, on drivers side you have the tensioner, and pass side is just a pulley belt rides on, that is the one squeaking. How hard is that one to take out? Anywhere I can get it other then Jag?
Old 12-18-2010, 10:07 AM
H20boy's Avatar
that's the idler pulley, I purchased an aftermarket one for $12 I think. I was hoping to just replace the idler and my tenseioner pulley with the same unit...no go.
Here's the replacement part - Dayco 89003, I think I got it from RockAuto.
MrWhite
19
06-14-2022 07:49 PM
mikiep
12-20-2019 07:37 PM
millertic
09-30-2015 08:11 PM
Col. Sandurz
09-28-2015 07:29 PM
Quick Reply: 97 Belt tensioner
