97 Front Right Strut HELP
I have a good used set of OEM Bilstein front shocks w/ new lower bushings you can have for $40 plus shipping. They have less than 50K miles. When I was rebuilding my front suspension, I thought shocks were causing a problem with shimmy and shake so I got new Bilsteins. Turns out they were not the problem and there was no difference in the ride. The old ones were just as good as the new ones. Now I just want to get them out of the garage. Let me know. Gordon
$40 for both fronts. Yes they are OEM Bilsteins, non-CAT, standard equipment on all '97 models. They should easily last for at least another 40K miles. Like I said, I thought they were causing shimmy in the front end. Later the culprits causing the problem turned out to be some rubber parts and bushings, and not the shocks. But by then, I already had installed new ones. They are just taking up space in my garage and I have no need for them. Gordo
Chuck Schexnayder
09-12-2015 10:30 AM
34by151
09-06-2015 05:14 PM
02jagstype
09-04-2015 08:20 PM
