97 Headlight moisture
Long time issue.
See the following:
https://www.jaguarforums.com/forum/s...light+moisture
and here
See the following:
and here
If I were to do this I would go to Jag and get a copy of the procedure and see if they have the “T” pipe. Looking at where the hole is to be drilled, moisture may accumulate in that area without the fitting…
Good Luck!
Gus
04 xk8 coupe driver's side headlight out
Got the moisture out. low beam bulb out. Fuse #8 blown. Replaced fuse; light worked, then fuse blew again. Tried the bulb & igniter on pass side & they are ok. Main light housing plug is clean.
Any tips on what's blowing the fuse? Probably a short from the water which was 1/2 inch deep behind the lens before drying.
Also having panel light issues that may or may not be related.
Fletch44
09-28-2015 02:21 PM
