97 Loose Door Mirror
Old 01-05-2016, 11:54 AM
skubeedoo's Avatar
Default 97 Loose Door Mirror
On the driver's door mirror, the mirror itself, the glass not the housing, is loose, it wobbles when driving. Is there any documentation for tightening it up?
Thanks in advance
Old 01-05-2016, 11:59 AM
jimbov8's Avatar
If I remember correctly it just clips into a housing at the back. It may just require a gentle push back to reseat it correctly.
Old 01-06-2016, 04:24 AM
skubeedoo's Avatar
It feels like something's not tight inside, the mechanism. didn't know if there were screws that could be tightened or if the mechanism is shot.
Old 01-06-2016, 04:27 AM
jimbov8's Avatar
The easiest way to find out is to pull the glass out and look at the mounting behind.
Old 01-07-2016, 11:44 AM
skubeedoo's Avatar
What's the best way to pull the glass out?
Old 01-07-2016, 11:52 AM
jimbov8's Avatar
Drive the glass to its innermost setting, for you that would be to the right. With your right thumb, press against the part of the glass that is closest to the door. Using your left fingers, place at the outside of the glass and slowly prise out.
Hope this helps you out.
skubeedoo
01-09-2016 02:19 PM
andrew_sankus
01-09-2016 08:54 AM
Gregor
01-06-2016 06:29 AM
NtAFord
01-04-2016 04:44 AM
JUNALUSKA BOY
General Tech Help
01-03-2016 05:18 PM
Quick Reply: 97 Loose Door Mirror
