97 smokes a little
Welcome to the forum!
You don't indicate the miles on the engine but check the breather tube from the right valve cover to the air filter\throttle body duct for oil. That might indicate you have a serious engine problem.
You car's model year indicates that you are subject to the Nikasil issues. See the FAQ Sticky above for more than you ever wanted to know on that subject.
Many recommend a higher weight oil and or an oil additive such as 'Restore'
My first Nikasil XK8 at 106k miles had new car compression and used no oil so maybe you are not doomed.
dmatthewman
09-30-2015 10:10 AM
