97 XK 8 key fob programming problem
I printed a copy of the instructions to program my key fobs and am having no luck. Heres what I did
1 inserted key in ignition but did not turn
2 Held signal in the flash position. (headlights turned on)
3 turned the key to #1 position
4 flashed 4 or 5 times within 3 seconds. Tried many times at different speeds but never got the chime so I could program.
What am I missing. Thanks in advance.
porkenstein (06-30-2011)
Thanks so much Landmannnn. That helped. I also think one of my remotes is bad. One will flash the lights and open the trunk but it won't lock or unlock the doors. The other remote has all functions. I am guessing if it wasn't programmed it wouldn't have any functions. I guess off to eBay for a key fob.
porkenstein (07-01-2011)
The back of the remote buttons are impregnated with a conductive substance. Over time the contacts on the PCB and the buttons get dirty. As you can see the buttons most used are the ones to fail. I repaired mine by taking the remote apart and cleaning the buttons and PCB contacts with denatured alcohol. Works fine now.
porkenstein (07-02-2011)
"The back of the remote buttons are impregnated with a conductive substance."
Wolfy
05-28-2024 08:06 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
