97 xk8 cup holder
97 xk8 cup holder
does not stay clipped shut. Something broke or missing? The little latch thing you push on appears in one pc but the place where it would latch on the holder part looks like it is missing something.
For a expensive car like this I have a handfull of BS plastic pc's here and there that are broke, cracked, etc.
The XK8 cup holder
The UK version of the XK8 did not have a cup holder. The one that they put in the US version just screams 'you want a stinking cup holder, here is a stinking cup holder'.
It does not work for its intended purpose, you go round a bend and anything taller than a soda can will slide out.
I was thinking about modifying the center console to remove the insert and machine two deep cup holder inserts from aluminum plate stock. If I could work out the wiring for the now obsolete cell phone I could put a bluetooth module in there and a satnav as well.
RFXJ12 (11-19-2015)
Phill,
Well I can see you are not lost for words! Like you said they do not work. I saw two modifications that had promise. One that was relocated to the side of the console. It appeared to be in the way of the seat moving forward or your leg. The second was to remanufacture the existing cup holder with a wood product. With this it does not close and hide. However, if matched with the wood in the car it could look nice if done correctly.
Gus
Gus
Hope this helps ,
N1XKO
I have the cupholder repair kits in stock. These replace the entire cupholder mechanism.
Here is a part number and price:
GNA7692AB $144.62
-David
www.Jpamporschejaguarparts.com
GNA7692AB $144.62
-David
mikiep
12-20-2019 07:37 PM
Pristine97XK8Convertible
04-28-2017 11:08 AM
