97 XK8 engine problem
Try replacing the ignition coils that are indicated by the fault codes. It looks like cylinder 1,4,6,7. Number one coil is the first close to the drive belt on the passanger side of the engine I believe. Number 4 would be the last coil near the firewall on the passanger side. 6 and 7 would be the middle coils on the driver side. Also do a hard reset and clear faults and see what happen. Put new spark plugs too, if you already haven't. If you have oil in the spark plug tubes, Replace the valve cover and spark plug tube gaskets.
BrentGardner
28
04-26-2024 03:08 AM
SingBlueSilver
08-27-2015 02:20 PM
