97 XK8 has Blinker Issue
The XK40's used to be super-sensitive to bulb quality and many owners often found problems with aftermarket bulbs. However, I've not read reports of this applying to the XK8.
Rapid (double normal speed) flashing is normally due to a bulb out but can be an indication (no pun intended) of a failing rear lamp cluster. Check the board in the cluster for bad tracks.
Evertrhing should be inspected...sockets, tracks, wires, connectors and ground connectors. If no problem is found, just replace the bulbs, bulbs are know to get out of spec. at times.
This car does not have conventional flasher, the flashing is controlled by one of the computer modules, called the body processor module (BPM).
Bigvettefreak (06-13-2013)
Im having this problem with the rear indicator on my 1997 XK8 convertible and I have the
pdf of how to fix but dont understand where to fix the free end.Any help would be great
To the metal body of the car, which is electrical ground. You can scrape some paint off the area around one of the tailight mounting holes and attach the wire under the nut.
The following 2 users liked this post by WhiteXKR:
Bigvettefreak (07-09-2013),
johnrobxk8 (06-12-2013)
Thanks for the pictures and info. Big help.
I have been trying to fix the problem by modifying the contacts themselves. I twisted them to better contact the inside of the plug. and so far it has worked. I am still going to do your repair now just t make sure it stays fixed. Jags seem to use poor grade metal for the boards and I am some what suprised they did it the way it was done. ok for the short run but fails over time due to cheap.
I finally got tired of the blinkers speeding up and the bulb failure coming on so I did the deed and fixed the ground wire. Now everything works perfect!!
I did not have to have the added ground wire go through the housing, the ground stud is coverd by the housing so I just did it that way nice and neat and no one can see anything different.
Thanks for the advice and the GREAT pictures, it made the job as easy as pie.
99xk8guy
06-05-2023 06:28 AM
