97 XK8 power steering rack and pump replacement
I am the new owner of an XK8. I bought the car as is and unfortunately when I received the car the power steering system was dry (no fluid). When I filled it with fluid it leaked at the pump and at the rack bellows at the tie rod. So it looks to me like the pump went and debris then ruined the seals on the rack. I am planning to replace the pump and the rack. My question is, how do I clear the system of the contaminants in the hoses and radiator before installing the new pump and rack so I don't ruin the new parts? Also, if anyone has done these installations, pump and rack, I appreciated any advice and specific steps to do the installations. Thank you in advance for any help here. Great forum.
Regards,
Jeff
Regards,
Jeff
Well if you install the new pump and attach the inlet hose to a supply of ps fluid, wouldn't that let you just flush fluid through?
Alternatively, get a drill driven pump from the hardware store, set one hose in a bucket of ps fluid, tape other hose to one end of the circuit and pump away.
You could also remove the cooler and take it to a rad shop for tank cleaning. Run rifle bore cleaning brushes through hoses.
This is the power steering system layout:
![97 XK8 power steering rack and pump replacement-xk8-power-steering.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/38076d1480967999t-97-xk8-power-steering-rack-pump-replacement-xk8-power-steering.jpg)
JTIS warns "if any major component is renewed, a new Fluid Reservoir, with integral filter, must be fitted".
Renewal may be excessively cautious but you do need to ensure the Fluid Reservoir (item 3) is thoroughly clean and unobstructed before fitting the replacement parts. This is best done off the vehicle. The Reservoir is attached to a bracket with two nuts and has a feed and a return hose secured with spring clips.
Guys - Thanks for the response here. I know a lot of this is common sense for those that do this stuff all the time. The information about the reservoir is interesting. I'll pull it and take a good look at it. It may be worth replacing to ensure the new rack will not generate leaks. Man this is turning into a big job. Frustrating for a first time Jaguar owner. Thanks you again for all the input. This is a great forum and website.
Best regards,
Jeff
Best regards,
Jeff
Best regards,
Jeff
Best regards,
Jeff
Ken K
FINALLY!
My son placed a 1/2" X 36" round breaker bar against the a/c pulley and gave the 5/8" stubby a little push. The nut FINALLY broke loose. That's way over the top for normal maintenance.
We have been searching for an "O" ring seal. So far, not finding one on the line connection or up in the pump with a small pick. All the replacements I see for sale have an "O" ring at the end. So....hmmmmmmmmm.....I guess removal of the pump has once again become mandatory.
![](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
I would rather keep this original HP line with the 90 degree bend. The newer lines/fittings look even harder to line up and start threading in.
Anyway, "good" for now.
Ken
I thought I could just pull the old "O" ring off the end of the HP tube and replace it, but it seems to be down inside some kind of groove. ???? Is there also a small flare to the end of the tubing? I don't quite get how that would sit inside the pump.
Ken
chupacabra
07-16-2010 04:53 AM
