97 XK8 rear speakers
Yes - as John says, the rear speaker "mesh" is held in to the panel cover by fairly insubstantial metal "tags". Sounds like somebody has tried to get at the the drive units by removing the "mesh" (which is possible) rather than removing the whole side panel.
The good news is that on a 1997 car, the rear speakers are actually bolted to a very substantial enclosure, so are never going to rattle or vibrate. If you remove the small "capping" on the door 'B' pillar - seat belt Torx bolt and a couple of small screws, you can get a piece of metal or long screwdriver or suchlike down behind the "mesh" to bend the tabs back tight again. But - don't worry - nothing is going to fall out even if it looks a bit "loose".
Johnken (10-29-2017)
