97 XK8 slow top movement
In addition to fluid level you might want to check what type fluid you have in it. Do a search for the fluid changes. There is an older type fluid that gels up and slows down the movement. Also while you are checking the fluid level there is a small petcock on the pump. It is a bypass valve for manual operation. If it vibrates loose it will allow a portion of the fluid and pressure to return to the tank slowing down the operation. Look for a T shaped rod and make sure it is tightly closed.
If you do find the tank low on fluid you should check for leaks in the 2 lifting rams and hoses.
Jandreu
03-14-2016 08:34 AM
