97 XK8 Tail light problems
The parking light and braking light are out on my left tail light. Getting the "Bulb Fail" message when I brake. Looks like the copper around the bulb housing might be damage. I cleaned it with a sandpaper and it did not help. Any suggestions? Worst case scenario = I found an 01 tail light. How hard these to mount on a 97? Besides cutting into the back end will I need to splice wires or is it plug and play?
Received 2,390 Likes
Try adding a separate ground wire
You could try adding a separate ground to the lamp assembly. Good idea anyway as the original on the connector isn't up to the job. This thread started by hacker-pschorr will show you what to do:
https://www.jaguarforums.com/forum/x...83/#post189210
lunaticpro (04-26-2018)
Yesh
I will try this! Thanks for the quick response!
renojag
05-14-2024 08:38 AM
Kikevzqz
12-16-2014 01:47 PM
SittinNmyjag
11-22-2011 05:44 PM
