97 XK8 transmission fault
Have a 97 XK8 with 66889 actual miles on it. We are getting a transmission fault warning and it appears to have gone into limp mode. I plan to pull this into my garage and attempt to repair or replace myself. Are there known defects in this particular year? With a sealed transmission, this doesn't seem like enough mileage for this type of issue. Thanks
Welcome to the forum. When you have time please visit the new member area and introduce yourself.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Use the search function for A drum failure and you will find many threads. Very common problem.
But first make sure the battery is not weak. It should give 12.4 V after sitting overnight. A weak battery will cause many different faults in these cars. And if you have access to a code reader that might be useful, but generic readers do not always pick up transmission codes.
aholbro1
08-05-2021 05:02 AM
