97' XK8 wheel bolt pattern?
Old 10-16-2013, 10:44 PM
Windycityx's Avatar
Default 97' XK8 wheel bolt pattern?
Anyone know what it is? For when looking at aftermarket wheels?
20" to be exact.
Old 10-16-2013, 11:21 PM
Rob Seignior's Avatar
I run OEM/std 18 inch flute style wheels. The P.C.D (pitch circle diameter) is 5 x 120.65mm.Translated this means that the wheel has 5 bolt holes and the diameter of the imaginary circle through the bolt holes is 120.65mm.
Rob Seignior, Australia 1997 XK8, BRG, 4 litre coupe
Syb (09-23-2019)
Old 10-21-2013, 02:24 PM
Default 5x120.65 vs 5x120 bolt pattern
Note that 5x 120.65mm equals 5x 4.75". Not to be confused with BMW 5x120mm. I personally decided not to ignore that difference when choosing wheels.
5x 4.75" is used on some American cars including Corvette and I've heard of people putting 120.65 wheels on 120 cars and vice versa.
Other compatibility details to beware of: wheel center hole too small for your car's hub, offset of outer and inner rim beads from hub (causing wheel or tire to rub on inboard or outboard sides of wheel well.
Syb (09-23-2019)
Old 10-21-2013, 08:21 PM
Windycityx's Avatar
What do you guys think of just running 5x120 as there seems to be a lot more options of that size then 5x120.65?
Old 10-23-2013, 09:12 PM
Windycityx's Avatar
Will this be a problem if I go with 5x120.65 instead of 5x120? Google has given me mixed reviews...
Old 09-19-2019, 07:07 PM
Syb's Avatar
Syb
Syb is offline
Default Syb
Those anyone know if there is a conversion kit ( spacer) from 120,60 jag to BMW 120.00.
Old 09-19-2019, 07:12 PM
Syb's Avatar
Syb
Syb is offline
Default Syb
Originally Posted by Syb
Those anyone know if there is a conversion kit ( spacer) from 120,65 jag
to BMW 120.00.
Thanks.
Old 09-20-2019, 11:21 AM
blindside's Avatar
I wouldn't bother... the difference between 120.65 VS 120 is .65MM (or ~0.0256 inches... that is ~1/40th of an inch). That has to be within the tolerance... and I have been running 120's on my car (that were on a bmw) for years with no problems. I would be more concerned with the hub bore and ensure that is perfect AND the offset.
Old 09-20-2019, 12:11 PM
Syb's Avatar
Syb
Syb is offline
Thank you for this information, I tried to slide the BMW rim over the jag bolts but it's to tight, I could drill the wholes out but not sure if that's the answer.
Old 09-20-2019, 01:40 PM
Higgins's Avatar
I use Bmw wheels on my Xkr 2000. They are TSW Chicane 5x120.65 20" wheels, 10" wide rear and 8.5" front. The center bore is somewhat larger compared to Jaguar Xk8 spec so a hub centric ring is needed. You have to be more careful when mounting the wheels to the car also otherwise they might get stuck on the wheel studs
Syb (09-23-2019)
Old 09-23-2019, 07:24 AM
I had my wheel off this weekend and it's a hub-centric mount, so it's the hub that carries the load, the hub diameter and hub opening need to match accurately, and the fit at the studs is less critical. Someday I'll try my BMW wheels on my XK8, but assuming the hub diameters differ, getting the correct hub centric ring is necessary.
Higgins (09-23-2019)
Old 09-23-2019, 09:04 AM
Higgins's Avatar
You're right. As long as you have the wheel hub centric you should be fine. But if the wheel is not perfectly centered, wheel lug nuts will stuck and some will not even thread.
Syb (09-23-2019)
Old 09-23-2019, 03:51 PM
Syb's Avatar
Syb
Syb is offline
Ok, however the jag has a73 mm hub. And the BMW has a 70 mm hub, not sure how the hub centric ring will fit.
Old 09-24-2019, 12:35 AM
TheBaltimoron's Avatar
I run 20" "BMW" wheels, the lugs fit fine though the radius of the hubs on the new rims were less than half a millimeter too small. I just shaved them a bit with a router and they fit great and are still hub centric.
Syb (09-25-2019)
Old 09-25-2019, 03:16 PM
blindside's Avatar
You will have to get the wheels bored out a tad to fit... I had contacted the manufacturer of my wheels and was assured there was plenty of room and girth that removing a few millimeters wouldn't be a problem (they would have done it for me if I was buying the wheels from them, but I had bought a used set). I think I paid $50/wheel to have the hub bore increased.
Syb (09-25-2019)
Old 09-25-2019, 05:23 PM
Syb's Avatar
Syb
Syb is offline
Default Syb
Thanks for all the advice I'm thinking ordering 4 custome made spacers, 4.75x 120mm with the right hubs. Does anyone knows a great company who will make them for me?
Appreciate your feed back
Slurpie
04-15-2017 10:31 PM
emaychbe
04-01-2017 12:10 PM
treese88
01-07-2013 06:03 PM
dallas_arctic
05-07-2010 09:42 PM
Jagged
08-07-2007 02:36 PM
Quick Reply: 97' XK8 wheel bolt pattern?
