99 xk stability /limp mode
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
99xk was showing stability/limp checked the codes and problem related to throttle sensor replaced the TB and on firing up the stability fail light back on with limp, did a hard disconnect of the negative battery cable and was unable to clear the limp. The signal returns with the key in the ignition and the system check pops up with stability /fail safe mode. this is witout starting the engine also Ihave had the abs module reworked I sure need some help thanks in adevance
Last edited by stillgotit; 09-07-2013 at 02:35 PM. Reason: change some grammer issues
I have on the instruments the engine failsafe mode and traction control fail
How can i solve this.
![Icon Mad](https://www.jaguarforums.com/forum/images/smilies/icon_mad.gif)
Also my foglights does not work
What fuse is the one i have to look for?
I was changing the lamp and they where on and suddenly they went out
Gert
Gert
Clean your wheel speed sensors first.
If you still have issues run through the checks outlined here:
http://www.jagrepair.com/images/Auto...heet%20XK8.pdf
If you still have problems repair the solder joints in the ABS module:
http://www.jagrepair.com/images/Auto...aul%20Bush.pdf
If you have the faults when you start the car before you move it, then you might want to consider doing the solder joint repair first, as that is the most likely problem.
Jaguar XK8 Wheel Speed Sensors - YouTube
