99 XK8 breather pipe
Can you be more specific as to which breather (or post a picture)? I cannot think of any that you have to pull through the way you describe.
larueb (12-09-2013)
Assuming you're referring to the part load breather pipe in which case you can fit it without removing the inlet manifold - I did- using a piece of string tied to the old one then using it to pull the new one in - in a couple of places you need to just help it along with a screwdriver from the top. However I did have to remove the throttle body to remove the connection in that area - it was too awkward with the TB installed. Replace the TB gasket and clean the electrical connectors whilst you're in there.
larueb (12-09-2013)
Pristine97XK8Convertible
04-28-2017 11:08 AM
Woznaldo
09-26-2015 11:02 AM
