99 XK8 Conducting Compression Test?
This is how I would do it, not to be confused with professional advice:
Remove what you have to in order to get to the spark plugs.
Remove the spark plugs.
Screw in the test gauge. Don't worry about getting it tight as there is an 'O' ring to seal the connection. Getting it too tight can result in the hose to spark plug connection turning rather than unscrewing at the bottom of a 6" hole. This will result in extended profanity. Ask me how I know.
Hold the throttle pedal to the floor, hard. That cuts off fuel and opens the throttle plate. After typing that I realized that I did not have a clue as to what happens to the fly-by-wire throttle plate when the fuel disable feature is used.
or
Remove the air filter to throttle body duct
Install a large screwdriver into the throttle body, handle first to hold open the throttle plate.
With the throttle pedal held firmly to the floor crank the engine for about 10 seconds.
Read the gauge.
Record the reading and move to the next cylinder.
or
Read the gauge.
When the throttle is closed no air flows into the cylinder so compression is zero.
............... Hold the throttle pedal to the floor, hard. That cuts off fuel and opens the throttle plate. After typing that I realized that I did not have a clue as to what happens to the fly-by-wire throttle plate when the fuel disable feature is used. ..................
![99 XK8 Conducting Compression Test?-fuel-pump-relay.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/48557d1480969083t-99-xk8-conducting-compression-test-fuel-pump-relay.jpg)
Still need to floor the pedal whilst cranking.
