99 xk8 fuel lines
hey guys, read and re-read the diy from Gus on fuel tank removal, mine is a 99 n0t a 2000 and i fear tyhe locations are different. cant find the disconnects from in front of or behind the differential. I got the gas out from the level indicator but i think i an still going to have to pull the tank out tio get to the fuel pump. please help
Here ya go. It's on Gus' site, but there's a link to it in the FAQs. It's a .pdf and it views better if you download it rather than viewing it in the browser window. You can zoom in on the pics for detailed views.
http://www.gusglikas.com/images/Auto...eplacement.pdf
That is very true......unless of course you get mad and a red mist falls over your eyes, the angle grinder comes out cuting a hole in the rear bulkhead and then passing very swiftly through the fuel lines.
Such a satisfying feeling, pure joy.
NOT, that I recommend you do that, it was on my track XK so it didn't matter none, and not that this post helps you any, lets just say I understand your pain
dont you know it guys. several problems exist with the fuel line tool: access is limited and sound dampening material. cant get the tool fitted behind the material, cant get it close enough any way without droping it. Jaguar must have a tool long enough to run it through the interferences to get it seated behind the fitting and pinch it back, kind of like a pair of nail pullers. i am going to make such a tool myself. i will post on it if it works
1964Daimler
09-09-2015 04:50 PM
