99 xk8 water in a headlight
I have discussed this someplace and cannot find it in search....i have water in my headlight, it stay there.
i drilled a tiny hole thinking it would drain, not
i used a hair dryer to remove the water, ok...but it's back again, must be some sort of gasket or seal, don't have a clue what to look for.
lights work fine. any thoughts????
Extensively covered on here. I searched this forum (XK8 / XKR) and got 131 hits using keywords water, headlight. My 'solution' is to not fix it. I figure if water can get in it can get out via evaporation, and it does. But I only get a few drops in there after washing (use a gentle spray).
Is it a LEAK or CONDENSATION? Both are known issues.
A LEAK occurs when the seal between the headlamp lens (item 2) and the headlamp shell (item 1) breaks down allowing rainwater or wash water into the headlamp. A considerable volume can build up. The two parts of the headlamp must be separated and re-sealed.
CONDENSATION is an annoying issues that was never effectively resolved by Jaguar. It can be a simple as a displaced access cover (item 3) or a faulty seal on the cover but even with a good seal, some condensation is unavoidable in damp climates. There is a discussion and details of the drain tube moification in this thread:
https://www.jaguarforums.com/forum/x...nsation-99097/
Even the drain modification won't cure it completely.
hirev (01-07-2019)
For the occasional headlamp condensation issue, the best solution is to temporarily remove the oval-shaped plastic access cover and park the vehicle in direct sunlight for several hours. Induced evaporation automatically cures the problem. Been doing this with my wife's 2006 XK8 ever since we acquired it in February 2012....
DavidYau (06-27-2020)
Timothy
05-16-2012 07:14 PM
