Aaaaaaaah! %$##@^%# Opportunists!
Old 10-24-2011, 03:32 AM
Felipe Pr's Avatar
Originally Posted by cat888
My '97 is Sherwood green, did you get your's repainted?
Yours look the same color to me, are you sure is named Sherwood Green?
  #62
Old 11-14-2011, 07:58 AM
Cat888's Avatar
I would prefer british racing green to Sherwood green pearl but on my door sill I have:
MFD DATE: 03/97
BODY: HFR (sherwood green)
TRIM: SDC (coffee)
VIN (last digits): 011097 (early model)
Here's an interesting article:
Central Valley Classic Cars :: The XK8 Color Mystery
I had a Series III E-Type V12 in BRG which is very different from HFR. BRG is not metallic while Sherwood green is pearl. HGG ('98 color) was apparently available at the end of '97 and Jaguar racing green HGZ not until 2002 (according to the article).
cheers Francois
  #63
Old 11-14-2011, 07:16 PM
Felipe Pr's Avatar
MFD DATE: 03/97
TRIM: SDC (coffee)
cheers Francois
Francois,
Well,always thought mine was BRG. after reading your post and attached article went to check my door sill and and found is HFR, Sherwood Green Pearl (like yours), also Coffee Trim. Something learned today thanks to you. As mentioned in the article, it depends on the light, or the angle you are seeing it, can be a metallic green, a blue/green or a dark blue. I like it very much.
Regards,
Felipe
MFD DATE: 10/96
BODY: HFR (Sherwood Green)
TRIM: SDC (Coffee)
VIN (last digits): 005438
  #64
Old 11-15-2011, 06:17 AM
Cat888's Avatar
Originally Posted by Felipe Pr
Francois,
MFD DATE: 10/96
TRIM: SDC (Coffee)
And me2 . Tell me Felipe, do you have the tonneau cover? I don't and it appears that the early cars are different but I dont know how. The lining is a bit dirty now and I want to clean it (what is recommended btw) and protect it in the future.
cheers
  #65
Old 11-15-2011, 09:56 AM
Felipe Pr's Avatar
cheers
Yes, I was lucky and found one 1997 Coffee original, used but in perfect condition on ebay about a month ago. The only difference is that the 97 car have a couple of male retainers behind the back seat at the top to secure the cover, the cover have the other female retainers in the center lip. Later cars (I don't know when it started) don't have those back retainers. Anyway, either with or without the retainers, any 97-06 boot cover will fit your car. On another post I read that an original OEM boot cover from Jaguar cost as much as $1,200.00, insane.
Try this http://vi.ebaydesc.com/ws/eBayISAPI....caz.html#thumb for $239.00. At least looks the same as the original. Perhaps if you contact them they will be able to add the back retainers for the 97.
I clean the liner with TUFF STUFF multi-purpose foam cleaner. I first apply a coat of the foam cleaner to an area of approx. one square foot at a time and scrub with a damp cloth or even a brush if there are heavy stains. Keep rinsing the cloth in clean water every time you clean an area. Works wonderful. It can also be used on carpet. You can find it in WalMart, Advance Auto, Pep Boys or many home and auto stores, is a very common product.
Regards,
Felipe
cat8881 (11-16-2011)
  #66
Old 11-16-2011, 08:00 AM
Cat888's Avatar
Hola Felipe,
Esta muy bien y gracias.
Felipe Pr (11-16-2011)
quaker13
12-21-2011 09:25 AM
Quick Reply: Aaaaaaaah! %$##@^%# Opportunists!
