ABS/ASC Message
ABS/ASC Message
I have been receiving these warning messages off and on for about two years. I have cleaned the sensors, connections, throttle body, etc. There is no pattern regarding when the error message will pop up. I would think a bad connection or module solder joint would result in a constant message until the problem is fixed. I'm tempted to ignore the issue until the light remains on all the time. Then, I'll tear out the module. I never have any driveabilty issues or need to limp home.
For my money, your symptoms point to an intermittent connection to one of the front sensors. Have you ever done the resistance check to those, while moving the steering lock-to-lock?
Last edited by Dennis07; 09-04-2011 at 07:59 AM. Reason: Try as I may, I just cannot spell.
I had the same symptoms and they immediately cleared up whin I finally had the module rebuilt. They did more than fix the main power connection, there are several soft spots in that controller. I was happy with Module Masters in Idaho. Fast and professional. About $150. Wish I had done it much earlier
I had a case with my own car where the symptom progressed from an occasional ABS warning, to frequent ones, to the warning appearing when I started the car. Traced to the RF wheel sensor connector. Cleaning and reseating it cleared the trouble.
It is very common in electronics for cracked solder connections to show intermittent behavior due to vibration and thermal expansion and contraction.
rominempire
28
10-08-2020 10:39 AM
