ABS/ASC/TRAC faults.
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
I have a question for our more 'hands-on' members. I've had a problem with my '00 XK8 a couple of times where, with no apparent warning or cause, I will get an enunciator panel warning that TRAC and ASC is not available, as well as an illuminated ABS icon and, sure enough, climbing on the binders demonstrates that I can, in fact, lock the wheels up. The trouble is that the warnings always go away if I shut the car off and re-start. Whatever is setting this off doesn't seem to leave a code that my OBD II reader can find. I have cleaned the wheel-speed sensors, and my next project would be to pull the ABS module, but would a cold-solder joint leave a permanent code, or only flag a problem when one of the actual joints vibrates open? Its only happened a couple of times, and never hung around long enough to plug my code reader in and castch it in the act. Any thoughts?
First off I would get your battery checked. Now I am talking about a test performed by Autozone, PepBoys or Sears they will perform a load test and cost nothing. This car is sensitive to voltage fluctuations. As for the module it could be the problem but I find it unlikely because you say you can shut the car down restart and it is gone. In most cases the ABS module problem you will start the car as it begins to move the ABS comes up, you shut it down and restart and it will do it again. The connection on the module that fails is the power to it, the simple vibration causes the inconsistent power to it causing the ABS fault.
Howdy, Scott
I'm becomming more and more convinced that at least half of these faults come from one of two known sources:
- the cold joint problem in the ABS module,
- intermittent connectivity in the connectors and short wire harness sections leading to the front sensors (these have to flex, the rears don't, or more precisely don't have to flex nearly as much).
There's some good news. We have a good chance of making an educated guess about which of these it might be by noting when -- under what conditions -- the fault appears.
If it happens when you first start the car, that would favor the first cause. If turning the steering wheel lock-to-lock a few times brings up the fault, that's probably the sensor stuff. It might take some watching over several days to see if a pattern emerges.
If it starts to look like the sensors, we can dredge up some old posts with procedures to isolate the bad guy (requires an ohm meter).
Good luck ...
Good luck ...
I feel the trouble shooting sheet will help but do not know the exact difference between the two MY I hope you find none.
Thanks Gus and Dennis. The warnings are now on constantly, and no longer disappear upon restart, but my OBDII reader is not throwing a code??!!
The ABS plug on mine seems to be the identical configuration to your (09) Gus, and all four WS sensors have an identical resistance reading, right on spec. They were all just cleaned (as per the Rev), so next stop is checking for cold solder joints. I was feeling fiesty enough to tackle it this evening, but I need to pick up the proper bitty socket for the mounting studs, so this step will have to wait until Tuesday, as it's a holiday here in Canukistan Monday, which just means even longer hours for us here in the Recreation Industry. Work; curse of the Drinking Class!
I messed around with a lot of checking, cleaning and whatnot before I finally solved my issue by going to Gus' website, printing the Hard Fault ABS Checklist and spending 1/2 hour following it's instruction.
If everything checks out at the CPU interface you can remove the processing unit (easy, 1/2 hour) and send it to Module Masters in Idaho (Module Masters > Home) and 3 days and $150 later your problem will be solved and warranted.
This cleared up my ABS/Trac fault lights immediately and also corrected the trunk light functioning....
This cleared up my ABS/Trac fault lights immediately and also corrected the trunk light functioning....![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
ModuleMaster rebuilds ABS modules for as low as $100, 2 day average turn-around, 5 Year Guarantee
Right name, wrong link...this is the place.
Sorry,
Sorry,
Well, I obtained the wee socket I needed, and boldly went where several of you have gone before. The ABS unit came out and apart just as advertised, but I was pretty bummed out when I saw that my solder joints looked perfect. Until I looked at them under a magnifying glass. Both broken. I would have taken a picture, but they look just like Dan's, Pauls, and others. Besides, I was too busy dancing around the shop and deciding which peat-flavoured bevvy I was going to celebrate with. Soldering and RTV seal are done, unit is back in Mr. J. Jr., and my ABS/TRAC light is gone! Halllelujah Bretheren and Cistern. This forum is....... Awesome. (I can't believe I just said that.)
Oh, and I settled on a lovely 15 yr old Scapa. And maybe more than one.
Thanks, Guys.
Thanks, Guys.
Thanks, Guys.
Thanks, Guys.
