ABS/ASC/TRAC Not Avail. Warning Lights - Help!
2001 XKR "Silverstone" Coupe.....
Been getting the above warning lights (intermittently), after car is warm. This only happens when I'm out and about, with stops for errands, etc. Every 2nd/3rd stop/start, lights will appear. Disappear the next time I start from cold - overnight. Even though dealership has been informed, nothing found to resolve problem - which is REALLY annoying! FYI, this car is only driven 1-2 times per week - sometimes less (1-2 per month). Any thoughts/advice? Many thanks!
Received 9,011 Likes
Both my XJ8s exhibit the ABS/ASC/TRAC Not Avail fault after the car has been sitting for more than a few days and the battery is slightly low. If I drive the car every few days I will not get the fault. My batteries are both about a year old but I know what the fault is and I deal with it.
I have too many cars and I don't drive all of them all that often.
Read the DTCs in the ABS module and see if you have the C1095 fault.
bob gauff
bob gauff
JimC64 (03-25-2015)
