ABS Codes 97 XK8
Today I used my AE software for the first time. I have both ABS and Transmission issues so I will start two threads.
ABS Codes:
C1155 Wheel Speed Front Left Input-Circuit Failed
C1233 Left Front Wheel-Speed Signal Missing
C1095 Hydraulic Pump Motor-Circuit Failure
I switched speed sensor with right front and checked connecting wire continuity, but the codes repeated on left front. I am thinking this is ABS Module problem, and I should send it out for repair.
Does anyone have other suggestions?
ABS Codes:
Received 2,192 Likes
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
