ABS Control Module - C1095 Pump Motor Circuit Failure
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
I have the yellow light warning says "Trac not available"
I cleaned all the speed sensors to no avail.
My ODB reader, under the "ABS Control Module" section, gives me a C1095 - Pump motor circuit failure
Is it likely that the "power connectors" have a dry joint and need soldering (in the ABS Control Module" ) is one of the problems I have read about.
Does anyone have any suggestions as to which pump motor it is referring to ?and where it might be? Is it more likely to need a new ABS Control Module?
Any help would be greatly appreciated, regards David
djpxk8 (09-19-2017)
The following 2 users liked this post by Gus:
djpxk8 (09-19-2017),
Robert Grisar (07-05-2018)
