ABS control Module change??
Hi gang,
In my guest to replace my former XK8, one potential unit has been listed as waiting to have an "ABS module being replaced". Is this a common problem, does it happen regularly, and is it something I should check to make sure it has been done correctly, and if so, how?
Any help would be greatly appreciated. Did not see this referenced in a quick run thru of frankc's lengthy explanation.
I think, but please correct me if I am wrong.. I am new to XK8's myself.... The capacitors in the ABS and ECU/PCM units go bad, they just corrode from the inside. Expensive to replace with new units, cheaper to repair. As long as your ABS light is not on, there is no OBDII error for it than the unit should be working.
There has been some discussion about how to remove the ABS module, whether or not you have to disconnect brake lines for access.
After that, it's not difficult. You need to split it open, solder two connections, and seal it closed.
I disconnected the brake lines so as not to risk damaging them. You then need to bleed the brakes.
I did mine a year ago and all is well.
zray (06-17-2019)
dsetter
02-02-2024 11:57 AM
JagYi
04-25-2022 07:00 PM
pomosv
10-11-2021 02:12 PM
69merccougar
01-20-2015 05:45 PM
jagosaurus
09-01-2013 05:24 PM
