ABS Diagnostic
Hi all,
I have had the bloody ABS light and the flashing Traction Control failure messages duo for the last 2months and with the MOT due soon I have finally set about finding the problem but could do with some help diagnosing the cause. here is what I have checked;
Fuses are all OK.
From the ABS module plug I have tested the resistance of all 4 wheel sensor circuits, and all four give a comparable resistance.
The previous owner said he had the ABS module repaired, but there was no receipt for this, so removed the ABS module found what looks to be a very tidy repair.
So does anyone else have any ideas what to do next?
Fuses are all OK.
These errors come up on startup every time the battery is weak, so there is that.
You can try and clean the sensors to see if it helps, and double check the reluctor rings and wiring to the sensors, especially in the front.
As you seem to have eliminated the low hanging fruits, you might have to use a proper Jaguar code reader to get the actual diagnostic from the ABS module itself.
The battery is quite new, after I experienced the multiple errors when starting up with a weak battery, and I use a battery charger/maintainer if car has not moved for week.
I forgot to mention there are no codes using an OBD reader. How does one find a Jaguar code reader? is that something dealers still have or is a case of find someone who salvaged one??
I forgot to mention there there codes using an OBD reader. How does one find a Jaguar code reader? is that something dealers still have or is a case of find someone who salvaged one??
I already have these readers
Very basic - Autel MaxiScan MS309 OBD2 & EOBD
More comprehensive - OBD Link LX used via Torque pro app
So would the The icarsoft and Foxwell be able to do anything different??
Great. So, I assume it has only recently shown ABS/TRAC errors, and before that it was fine while you've owned it?
Edit: I have the Foxwell, and it's a bit limited compared with IDS, but should show the Jag P codes with the JLR module installed.
I have used Autoengenuity for years and the only thing I can't do with it is reset SRS codes, something I need to do.
Yes, generally U and C too. Quirks include if you’re not doing an overall scan, for example you want abs only, it might find nothing when the overall scan is reported properly.
Any generic scanner will show P codes. I was under the impression it would also display and erase C and U codes. I use Autoengeniuity which does that, but will not reset SRS module functions, which I need.
And yes, fmertz, specifically for 2001 and beyond. I suspect much commonality before this based on the structure of the CAN and SCP messages before 2001 compared with 2001, but don't particularly recommend the Foxwell anyway. I just happened to have it and bought the JLR module.
If I didn't have it, I'd stick with some form of IDS, which is a bit more cumbersome because of the need to relentlessly keep the computer from updating itself and killing functionality. For example, IDS doesn't work for me right now because I didn't previously have a dedicated computer for it, and the computer updated itself against my attempts to permanently stop it.
