ABS failure XK8 1999
Guest
Posts: n/a
Hi,
Just bought an XK8 1999, 46K.
I was driving the car yesterday when the ABS light went on and a "System failure" message appeared. I turned off the car at the gas station for a few minutes and turned it on again. The light and error message were nothere anymore. Didn't get this error since then.
I also noticed that the car doesn't go straight, it's laying left or right sightly. Wonder if it's linked to the error messageor if it just needs an alignment.
RE: ABS failure XK8 1999
I found at times that improper tire pressure would cause the car to feel a bit out of alignment. I would check that first before going for an alignment. As for the ABS I had a problem with mine and had to replace the ABS control. If I were you I would check your sensors to see that they are clean first and also see if you set an OBD code before spending any time and money. I have heard of people having the ABS control rebuilt. However, I have no ides if it is worth the effort. Good Luck!
I also had the misfortune of replacing the Brake control module (more than $2k). Hopefully it is just a cable between the sensor & the module which will be closer to $100. These electrical issues are not likely to be related to an alignment issue.
Just keep thinking how beautiful the car is and you'll get the kinks out eventually...
Doug 2001 KKR convertible
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
