ABS light on
My reader will not pull the ABS codes, so I am getting them pulled tomorrow. ABS light comes on as soon as I start the car, used to come on every 2-3 weeks. I cleaned the rear sensors and re-soldered the ABS, but I cannot get the front caliper bolts off to check the front. I used a 22oz hammer with a breaker bar and could not budge the bolts.
So, what else besides the front sensors should I look for?
RandyB, here is a link to a thread that I started about my ABS problems and I solved the problem. Read it for yourself it may help. https://www.jaguarforums.com/forum/x...esolved-95556/
Good luck and
Happy Motoring...
Good luck and
Happy Motoring...
Chances are pretty good it's one of the connecting cables if not that the sensors need cleaning. It's not too difficult to swap the sensors and cables side to side and see if the code moves, assuming it is a sensor connection code. I hope you don't have to visit the dealer to read the codes.
rsa760041
23
09-25-2015 01:33 PM
innzane
09-02-2015 10:08 AM
