ABS light on
This should help
Link http://www.jagrepair.com/images/Auto...xk8%201999.pdf
The C1107 is not listed but it stands for ABS function enabled input circuit failure
I sent mine out for repair twice. If the problem is C 1095 they can fix it by resoldering the contacts, but so can we. My other problems were never fixed, and on the last attempt the module stopped communicating with the ECU, which made it look like it was working, but the cruse control would not function. Replacing it with a used module solved the problem, although I had to fix a C1095 issue myself. But the vendor refunded my purchase price because of the code.
spoke to soon, got the 1137 back, so I am guessing I have a wiring issue. Go figure!!
The other thing the car is doing and has since I have had it, is that at low speeds the front right brake will lockup for just a second. Always under 10 mph, pretty sure it is not related, but wanted to throw it out there.
Any known ABS wiring issues at the module connector?
BTW: replaced pump at same time I replaced the module.
rsa760041
23
09-25-2015 01:33 PM
innzane
09-02-2015 10:08 AM
