ABS light-No ASC/No traction lights - RESOLVED
Hey Mr. Feather, yes in theory you can just place new wire.
My left harness had broken wires at the speed sensor connector and I cut the wire stripped back the insulation and inserted the wires back into the connector and epoxyed the connector and the wire and taped with electrical tape and worked just fine.
I suggest once you do place new wire, that you check the resistance of the connector should be 1.5 ohms or less.
If you look on ebay you can find better deals on harness, I found a new one for 45 bucks. The front harness part numbers for my car was LJD3410AA . This info should make it easy for you.
Good Luck and
Happy Motoring...
Good Luck and
Happy Motoring...
Mr. Feathers (08-07-2013)
zray (01-22-2024)
I know this thread is 10+ years old. I don't know if you are still an active member.
If you are,maybe you can help me. I have been plagued with ABS system problems for over 2 years that has kept me from passing CA smog rules so I can get my new tags and drive the car legally.
I have had the ABS module and the ECU professionally refurbished. I have had only about 1 month without the "Christmas Tree" in over 2 years.
My next task is to check the continuity of the CAN. Easier said than done for me. I have the tools, and another member gave me a set of schematics that help, but I am not sure I can identify the correct probe points at each and of the CAN wire.
Do you have any tips for me?
Ken
Ken
#28
Ken
Ken
I kept getting ABS codes, TRAC and ABS messages, etc. One code was module-related, the other for left front speed sensor. After rebuilding the ABS module I still kept getting ABS errors when turning left. The left front speed sensor error was still present. I replaced the LF sensor wire harness and the problems went away.
#30
This is a problem where you're going to need a good code scan. Have you scanned, and, if so, what errors did you get?
I've really gone the rounds with this problem. The constant recurring code that plagues me is P1637. Even a local Jag shop stopped and wanted to sell me a new (rebuilt) ABS module because they said they could not go any further because there was no communication between the ABS module and the ECM. I already knew that. DUH! So, they were no help, hence the refurbishing of both the ABS module and the ECU. Nothing has worked, so I'm left with doing a continuity test of the CAN between the modules. A member has posted up a schematic of the wiring for those two modules, but I haven't been able to get in there are open it up yet....and I'm still not sure how to identify the ends of the two yellow and green wires at the connection points.
Ken
Y2KJag (01-26-2024)
#31
Ken
Ken
This is a VERY lengthy thread from another member with a '97 and his P1637 problems. It's a long read, but very informative. I'd have pushed the car off of a cliff long before, so kudos to him for sticking with it.
hafren
09-07-2015 10:30 AM
innzane
09-02-2015 10:08 AM
