ABS module
Old 08-22-2016, 10:26 AM
98 shadow's Avatar
Default ABS module
Trying to get the ABS module out, E5 reverse torque no problem but windshield washer neck in the way. Has any one removed this and how (windshield neck)
2001 XKR
Old 08-22-2016, 12:14 PM
RJ237's Avatar
Received 2,805 Likes on 2,238 Posts
The neck just needs a twist to remove. Many have claimed they bend the brake lines out of the way, but I prefer to disconnect. If the system has not been flushed in the last two years you should do that also, so getting air in the system is not a problem.
Old 08-22-2016, 12:43 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
I recently pulled my ABS 4 mounting bolts, 1 plug and 4 bolts holding the control module in place. The removal of the mounting bolts allows you to move things without any serious bending.
RJ237 (08-22-2016)
Old 08-22-2016, 06:00 PM
98 shadow's Avatar
many thanks. I love this place as much as the car,maybe.
