ABS module
Does anyone know if the abs mod controls the speedometer on the dashboard had a problem yesterday. Lights on dash said abs,trac,gearbox,safemode, car wouldn't shift from park .so I unplugged the ABS MODULE, then was able to get the car in gear.and drove her home. But still have light all over the dash . when I plug the abs back in the dash will say incorrect part , the trans stays in park. So I assume the ABS MODULE is bad . and do I have to get this thing reprogrammed when I change it out (LNF2210AD)
This all started with abs trac control warning light coming on .2002 XK8 4.0 with 70,000 miles any help would be appreciated.
Orthodixie (06-22-2017)
Doug- I have a similar problem in that the ABS and TRAC warning lights came on. After cleaning all sensors and checking fuses and relaysand when I drove it I had still had no speedometer. So now I am still reading and checking everything I can find. Sooner or later one of us will cure the problem. I am posting all I am doing as I go along. Good luck.
First be aware that the part number is NOT LNF2210AD but JLM21323.
The number printed on the modules case is not a recognized Jaguar #.
You either have a fault with the CAN bus or the ABS module is faulty.
Sometimes a used ABS module will need to be configured to the car and sometimes it is PLUG & PLAY.
A NEW module will ALWAYS need to be configured.
bob
bob
kstevusa (12-13-2021)
The ABS module has a design fault in its power-supply connector-post/solder-spot on its circuit board which causes an intermittent/permanent open-circuit, triggearring the ABS error-warning. Check this forum for ABS module faults and remedies. I re-soldered my ABS module power supply posts and fixed the fault.
Good luck with yours...
Augeter (06-27-2017)
Motorcarman suggested there could be a problem with the CAN bus. Does that mean the entire harness is corrupted or not connected? Should I be tracing the harness....not that I know what I'm looking for.
My module has been saved by Module Repair Pro, Van Nuys, CA. $100 plus shipping both ways, but it was worth it. I don't know exactly what they did, but everything works now. NO MORE IDIOT LIGHTS. No "WRONG PART INSTALLED" messages. No DTCs. I cleared whatever codes might have been there from before, then plugged everything in and powered up. Great! I drove around and put 34-40 miles on straight and very twisty roads at various speeds. Speedo/ODO works again.
Resolution update:
Any suggestions would be greatly appreciated.
Ken
JagYi
04-25-2022 07:00 PM
