ABS Module Configure?
If your INST PK display says 'WRONG PART FITTED' or 'INCORRECT PART FITTED', then you need to have it configured to your car.
All 2001 to 2003 XJ and 2001-2002 XK use the JLM21323 6 pipe (9 valve) modules with BLUE solenoids.
The module does not need to be programmed (no data changed) but it might need to be configured to YOUR CAR. It is on the CAN bus and the network might not recognize the module until it is configured to the network. (everyone needs to 'shake-hands')
Why do you think you need to have it configured?
bob
bob
motorcarman (09-02-2016)
frombenz2jag
01-17-2008 06:45 PM
frombenz2jag
01-16-2008 05:38 PM
