ABS Module and Model Year
Generally speaking, if the part number suffix increments by a letter or two, you would be Ok. For instance, LNC2210AD would replace LNC2210AC. Also be sure the number of solenoid coils you see on the backside is the same; and the function designation is the same. I.E. ABS, ABS+TCS, ABS+TRACS. Steer clear of a PREFIX that is different, some are LJA, LJE, LNE, LNA for example.
Gee, harder to explain than it is to practice.
Cheers,
Cheers,
Spurlee (02-22-2011)
Wolfy
05-28-2024 08:06 AM
