Abs module necessary?
I'm in the process of changing out some parts with my car and all and I realize I need a new abs module as well. But is the abs module REALLY important? I know it should be changed, especially due to the faults being up, but that money could be used for something else towards the car. Is it really that important to have? Lol I've been riding 2000+ miles without it anyway
What makes you think it needs to be replaced rather than repaired.?The most common fault is a cold solder joint on the pins to the abs pump, an easy diy which has been covered many times on the forum.
If you have the codes read by a foreign car shop with the necessary software and report the codes here we can help.
Look at it from an integrated perspective. The input from the ABS system (individual wheel speed) is available/broadcast on the CAN network for general use. The transmission module uses it for road speed (although there is a backup), and the ECM likely uses it to modulate the throttle under hard acceleration (traction control). I would definitely look into getting this module functional one way or the other.
Unfortunately from an MOT point of view, as its a standard fitment and is a safety device, then it must function otherwise its a fail
dsetter
02-02-2024 11:57 AM
JagYi
04-25-2022 07:00 PM
pomosv
10-11-2021 02:12 PM
69merccougar
01-20-2015 05:45 PM
jagosaurus
09-01-2013 05:24 PM
